Maho 800P
Likes Likes:  0
Results 1 to 5 of 5
Thread: Maho 800P
    Oct 2014
    New York
    13
    Default Maho 800P
    Does anyone have a start up procedure for the Maho 800P.
    An older friend purchased a used Maho 800P from General Dynamics in Michigan back in 2010. This has the 40 National Tool Holder. He hooked it up in his shop and was able to manually control the machine (move the table, rotate the head, move the head up/down, etc). He never got around to learning how to program the computer, as the project he was planning to use this for was cancelled. So it has sat in his shop since then unused
    He tried starting it recently and was not able to get the table to move (where he had moved it before). He did get the head to rotate. He does not have the manual for this machine and he could not recall what he did to get the machine to manually work.
    Is there a start up procedure for this machine? Any thought on what the issue might be?
    Dean
    Oct 2006
    Mediapolis, Iowa
    1,711
    363
    379
    Is this the machine you are referring to: Maho 8P Milling Machine w 4th Axis Rotary Table | eBay
    Oct 2014
    New York
    13
    yes, that is the machine
    Jul 2016
    ROMANIA
    14
    Is that TNC 155 operating sistem? If so, I have the operating manual.
    For TNC usualy the start procedure is...Press CE button when Power Interupted apears then activate hydraulics(dor switch) and after that pressing the Feed ON button and in the end press on the axis you whant to move to pass the reference points. Don't forget tu lift the Emergency Stop button if is pressed. Good luck!
    Jan 2005
    The Netherlands
    5,580
    248
    1373
    Manuals for TNC controls can be found on the Heidenhain website
    The older ones are hard to find (Even a search will not find them )
    Here is a link
    Home: Software - HEIDENHAIN
    Click on cnc controls
    Click on "Others" for more controls
    Click on the controle you are looking for (TNC135 I think)
    Then click on the documentations PDF file you need
    The download button appears just below the picture
    Peter
