Maho MC5HS gearbox drawings?
Likes Likes:  0
Results 1 to 2 of 2
    Mar 2006
    Russia
    41
    Default Maho MC5HS gearbox drawings?
    I try to restore (and retrofit linuxcnc) the old maho, cannot disassemble the gearbox for replacement of bearings.
    There is a suspicion that the bushing (2) in which splined shaft (1) holder is pressed was turned inside main body (3) and block screws (4) which fix a splined shaft. It's possible?
    It would be desirable to look at the drawing of this assembly.
    Mar 2006
    Russia
    41
    Solved, thanks for participating.
