MAHO MH 300 C Hydraulic dead
Likes Likes:  0
Results 1 to 4 of 4
    Jun 2021
    SWEDEN
    Default MAHO MH 300 C Hydraulic dead
    Hello everybody!
    I just bought a MH 300C with Philips 432, worked when I loaded it at the seller but when I plugged it in at home the hydraulic started one for about 2sec then nothing happening after that when I press the hydraulic button, like an E-stopp is pressed.
    It has three E-stop, one on the panel, one on the side of the cabin and one on the handwheel, when I press the E-stop on the handwheel the actuator clicks in the cabinet but the other two is dead, no actuators respond to those two.
    The TRK6 show FUL error.
    Anyone have a clue on what could be wrong or what I should check?
    I'm new quite new to this, haven't used a CNC mill/lathe for about 20 years, and that was in school...
    When I first plugged it in, the monitor was crazy, looked like matrix with flimmering screen and completely unresponsive.
    After a couple of hours the screen begin to work properly
    I tried to change the order of the phases if that should be the problem but that only showd more error on the TRK6 module.
    Is there some glass fuse that I could have missed thats broken?
    I have run the diagnostic but can't find anything that looks odd compared to the manual.
    Please give me some suggestion on what could be wrong or what I should check.
    Mar 2008
    vacaville ca
    569
    90
    151
    swap 2 leads, probably running pump backwards
    Jun 2021
    SWEDEN
    Quote Originally Posted by pcasanova View Post
    Hi
    Already tried that several times, the pump doesn’t even tries to start, error 54, 55 and 57 shows on LCD on the side of the machine.
    And the screen shows chess-like ”pixels”
    Mar 2008
    vacaville ca
    569
    90
    151
    only thing i could really think of. if it ran before you moved it try re-seating cards, maybe something loosened up in the move.
