MAHO MH600C / 432 control is freezing
Results 1 to 14 of 14
    Sep 2015
    10
    Default MAHO MH600C / 432 control is freezing
    I've got a 1989 MAHO MH600C with Phillips 432 control and 4th axis. It has served me very well for the past year that I've owned it, but suddenly I'm getting a strange malfunction where the control freezes up in a manner that I cannot figure out. I can turn on the machine and set the 4 axes toward their reference points; when I do this, all four axes move properly but once they get to their reference point locations the control freezes up.
    When the control is frozen, I can cycle E-stop and then power-on + clear twice to get the control unfrozen.
    Once I've unfrozen it I am not able to jog XYZ axes, but can still jog the 4th axis. When I let my finger off the 4th-axis jog button the control freezes again and the 4th axis does not engage the hydraulic brake like it should.
    Another thing that I can do when the control is unfrozen is that I am able to move the XYZ axes 0.1" at a time by putting it into 1000 step mode and pressing any of the 6 +/- buttons for the XYZ axes. When I do this, the machine makes the movement, but then freezes after it moves 0.1"
    If I do this 10 times in a row (move 0.1" and then unfreeze machine again) then I can get enough clearance (1") to make a running start at the reference point again. I unfreeze the machine and send it toward the reference point on the axis in question -- it behaves as it should but then once it gets to the reference point the control freezes again.
    I hope I'm describing this behavior adequately.
    A few things to note which may somehow be relevant: I've got a lot of weight on the table. In order to compensate for this, I have adjusted the machine constants to slow down the max rapid speed on all axes, which has helped me avoid position following errors on the Y-axis (which is the axis which moves the table up and down). Slowing down the rapid speeds and max feeds has been a good stopgap measure, but I noticed that over the past few months I've needed to keep slowing it down further every few weeks in order to avoid errors. Lately I also have needed to manually jog the Y-axis up and down at 75% for several minutes before I can get it to jog up at 100% of the already reduced feedrate.
    Taking that history into account, I suspect that the drive for my Y-axis may be wearing out, and I'm wondering if this new behavior of the control freezing is perhaps related somehow?
    FYI, this is the exact same machine referenced in this thread:
    89 Maho MH600C Y axis problems
    In that thread, he mentions that he also had a lot of weight on the table and that he had to replace the drive for the Y-axis. Perhaps it's time to replace it again?
    Thanks in advance for any help or suggestions that anyone can give me.
    Oct 2006
    Petaluma CA 94952
    537
    77
    Lee, Yeah, I think thats pretty much what happened to me except the Z axis didnt fail gracefully. Just stopped one day at startup. Its been said in other posts about the KDA indramat drives that the large caps go bad and should be replaced. I never tried to repair it, just swapped the drives to verify. Bought the same drive on ebay for $280, swapped the personality modules and its worked till now.
    Sep 2015
    10
    Thanks Mark! I found an old drive on ebay that got pulled from a very similar MAHO, so hopefully it will work for me, but even if it doesn't solve the problem it was cheap enough that it could still be useful as a debugging aid. I will report back when I've done the swap-out experiment. I need to trade the programming module from the old drive and put it on the "new" one, right?
    Also, here's another question: when I open the electronics cabinet there are three switches -- one overrides the axis limit switches, one enables programming the system constants, and the third one puts it in some sort of debug mode. I run the "drive module" part of the debug mode and it errors out on module #3 (out of 3 total) saying that drive #6 is not present. That's to be expected though, right? Drives 1-4 are the axes and #5 is the spindle, right?
    Oct 2006
    Petaluma CA 94952
    537
    77
    The other thing you should do is check (carefully)on the three copper bars connecting the drives and servo amp power supply to be certain that you have 300VDC across all the bars. I never had that problem on this machine but it could also be a problem with the servo power supply. Sounds like the z axis servo. There should be an error code on that drives LED screen. I think I gave you an indramat drive manual with the machine.
    Sep 2015
    10
    Mark, upon your advice at the time we transferred ownership, I downloaded the drive manual entitled:
    MAC Servo Drives
    with TDM and KDS servo drive modules
    Applications manual
    Document No. 120-0001-B301-02
    Date: Sept 1999
    Number of pages: 186
    So anyhow I'm armed with that, but haven't dug too deep into it yet.
    Lately I've been running the machine exclusively in horizontal spindle configuration, and have switched around the system constants so that the Y axis lifts the table up and down, rather than the Z axis as you were accustomed to.
    Anyhow, the problem I'm having with the control freezing is intermittent, and so it seems like a 50/50% chance whether the machine will function properly when I turn it on. I wrote a simple "warm-up" routine that jogs the axes back and forth indefinitely, and it will go on for hours until suddenly it stops with a frozen control. The control always freezes at the end of a move, after it's already completed motion, but before registering the move as complete.
    As it turns out, I was lucky this morning and the machine turned on properly and is running it's warm-up routine at 80% rapid with no problems whatsoever. I measured voltage across the DC terminals of the drives, and am reading 307VDC whenever the X and Z axes are moving, but when the Y axis lifts the table up, the voltage drops down to 306. When the y axis drops the table down, the voltage goes up to 310.
    I will report back with some voltage readings the next time the control freezes.
    Sep 2015
    10
    OK, and the control froze up not too long after writing that last post, once again after it had completed a movement. The DC supply voltage on the drive bus bars was 309VDC.
    Sep 2015
    10
    Hi Mark, and anyone else reading this tread:
    My replacement drive from EBay came in a little while ago, but I haven't taken the time to debug my MAHO with it yet because I've recently started a new job at Autodesk Pier 9 in San Francisco that gives me access to a brand new Matsuura MX-330 5-axis machine. In light of that, my motivation to fix the good 'ol MAHO has dropped substantially, and so I'm thinking that it would be best to drain the coolant tank and pack up my tooling to take to San Francisco with me. I'm sure I'll get around to debugging this MAHO problem before too long, but in the mean time I'm just excited to finally have access to a 5-axis machine, and am focusing my energy in that direction. I'll report back to this forum thread in the coming months when I have more information about whether the drive replacement fixes the control freeze problem I'm having.
    Lee Krasnow
    Pacific Puzzleworks
    Sep 2015
    10
    Hello World!
    Well I'm back to this thread a couple of years later. I've since moved the non-operational machine to a new location and have powered it up successfully but still have the same drive problems as before. I tried swapping out the drive with that replacement one I bought on eBay a few years ago but that didn't solve the problem. My more immediate hindrance to further troubleshooting is that the battery doesn't seem to hold a charge for more than a few days now and so I have to re-enter the constants pretty frequently if I forget to leave the machine powered up. Any idea where I find that battery in the control cabinet? Is it like a coin-cell thing on a circuit-board?
    -lee
    Sep 2015
    10
    Hi again, having just posted to this thread about the dead batter, I got all inspired to give it another good burst of troubleshooting. The overall situation is much simpler than before because I've removed the 4th-axis and all of my heavy fixture components from the table so theoretically the machine should have an easier time lifting the Y-axis load, but it's pretty easy to make it error now whenever I want to (I guess that's the benefit of waiting years to fix this problem, right?)
    I can startup the machine fine, and I can home the axes fine. I can jog fine in all axes except if I jog the Y-axis up and down (meaning that the machine table is lifting up and down) then I can only go up/down a few times before the machine faults out with an error of Y09 I05 it always seems to happen on the up-stroke (meaning where it's lifting the weight of the table up) and when it happens the sound of the drive motor changes in pitch upward noticeably. This is accompanied by an increase in the axis drift reported on the control screen (because I've set C81=1 in order to see the axis drift reported to me)
    I've looked at some other threads on this forum about Y09 I05 kind of errors and specifically this one:
    Maho 600E2 - Dynamic following error - Y09
    pretty well describes my situation perfectly. I have taken the advice in that thread and tried turning off the dynamic following error (I just shut it off for all three XYZ axes @ C210, C260, C310) and the problem still happens but in a strange new way:
    with the dynamic follow error control turned off, the motor still spikes in pitch frequency, and the axis drift reported on the control screen still jumps up. At this point the way that the machine locks up is a little bit different than before: the control stays normal and I can still operate any of the other axes, but the Y axis is now dead. When I look inside the control cabinet the Indramat drives, the one of the now frozen Y-axis has three flashing lights on it as if it's still trying to move the axis somehow.
    I've also tried running a simple test program in Auto mode which works OK sometimes, but freezes the control other times. If it happens, it always happens on a rapid move lifting the table (Y-axis) up. The difference between when it works and when it doesn't is that if the axis keeps up pretty well, or only lags a little bit (as determined by whether or not I hear a pitch increase in the sound of the motor working) then it will probably make it through the program OK... but if the pitch increases a lot then the control will freeze.
    My next plan is to try swapping around a few of the drives inside the machine and see if, for example, swapping X & Y with each other has any effect.
    Also, it's worth noting that I recently cleaned the glass scales pretty well so I don't think it's an issue related to that feedback system.
    Thanks for any help anyone can offer me on this topic.
    -lee
    Oct 2006
    Petaluma CA 94952
    537
    77
    Its the big lead acid battery behind the panel on the right side of the controller. Dont remember the exact amp hour. Small motorcycle size. I put a new one in the machine when I got it but they need to be topped off every few months when in good condition.
  11. #11
    Sep 2019
    SWITZERLAND
    8
    Hi Lee
    Just registered to (maybe) help you...
    Check this: if the control "freezes", open the cabinet on the right side an take a look at the belt that drives the spindle of your Y-axis...
    If you see it turning and turning an turning but never reaching it's position, you have the same problem like I have...
    The safety clutch of the Y-axis has to be cleaned an re-torqued....
    stop swapping drives arround an change stuff in the machine data... I suspect a purely mechanical problem...
    one other posibility is, that the axis is a bit jammed cause of swelling plastic sliding surface... means, the clutch does what is should, limit the torque..
    with machine constant 81 set to 1 I see, that my machine tries to reach the 0.01 positioning window, but it "hangs @ 0.12-0.14... with an iron bar i can push the table a bit up, then it goes on...
    sorry for my english
    greetings from switzerland
    bear
    PS: i have a MH700C/A
  12. #12
    Sep 2015
    10
    Hello Bear,
    Thank you for posting this information! I have actually already fixed my machine a few months ago but forgot to update this forum post with the answer. You are correct that the problem was related to a slipping clutch on the Y-axis, but that was only half of the problem because also I was having problems with the power supply for the 432 control. It sounds like your clutch was slipping more than mine was because the only way I was able to figure out it was the problem was by making black marks (with a pen) on the pulley to show where the two halves of it were located in reference to each other and then I ran the Y-axis up and down a few times and looked at the black marks again. In my case, the two black marks were no longer lined up with each other, so I followed the maintenance procedure in the manual for adjusting the tension on the clutch.
    My other problem was that the +15v and -15v voltage regulators inside of the 432 control power supply unit had worn out over time and were not outputting consistent voltage anymore. I spoke on the phone about this with Karl the MAHO doctor and he explained to me that the 432 control communicates its desire to move axes around (including the spindle) by setting very specific voltage levels on the control lines to the Indramat drives. For example, when the 432 wants to shut off the spindle (M5) it sets the control voltage to zero. Because my voltage regulators were old, they were outputting inconsistent voltages and so when the 432 control tried to turn off the spindle, it was actually still moving at a very slow RPM because the voltage level coming into the Indramat drive was not close enough to zero.
    I put a short post on my Instagram account about having fixed this, which includes some photos of the steps that I took to do it. Check it out here:
    Pacific Puzzleworks on Instagram: “I’ve finally finished fixing my formerly non-functioning CNC milling machine! As it turned out there were two problems preventing this…”
    Anyhow, the machine runs great now; perhaps it runs better than I've ever experienced since owning it. I did not anticipate how big of a difference in cut quality I would get from rebuilding the power supply. In particular, I notice that my circular arc moves produce much smoother profiles with less.
    -lee
  13. Likes petar712 liked this post
  14. #13
    Sep 2019
    SWITZERLAND
    8
    Hi
    you're welcome
    Good to hear that your machine is running well !
    and also good, that the info is now in the forum. maybe it helps someone else one day !
    bye
    bear
  15. #14
    Sep 2019
    SERBIA
    Hello lee,
    only 15 days from your post and you already helped me,
    exactly the same problem with my MH-800E and same solution.
    I was looking for an answer for days and ended here, thank you!
