Modig 7200 and machine killing field
JHOLLAND1
Titanium
Oct 8, 2005
western washington state
the Modig 7200 made the move from Boeing to the killing field of machine tools in Olympia
it rests upon the spot occupied by the Makino A55--
but a more noble fate awaits the Modig than the long knives the Makino submitted to
the plan:
all sheet metal is stripped off
Fanuc red cap servos are removed
machine spindle and housing are pulled
tool changer goes
lube units remain --if possible function consolidated
chuck jaw motion on rotary tables is hydraulic--much smaller hydraulic
pump/motor assembly or pneumatic function are likely---fast cycle time is
not needed--reducing killo-wattage is
step motors or brush servo motors go where red caps were
Hypertherm plasma torch to be placed on Z column
chuck jaws to be modified for tube
jh
pics2-------------------------------------
pic3-----------------------------------------
sheet metal now off the Modig
machine head has counter weight--calculated mass 475 lbs
mill head is sub-assembly bolted to machine frame
plan is to fasten counter weight chain to casting then remove
weight
seven studs/nuts hold head casting to frame--these will be removed
and head assembly lifted
remainder of machine is then ready for transport to my facility
for conversion to plasma cutting rotary
jh
