Utry2win
- Aug 17, 2011
- Lakeland, FL
Ok, So we have a new to us 2005 Mori MT-2000. Just got power hooked up today, and testing functions. Everything is working as expected so far with the exception of moving the tailstock. The manual says I need to command a M479 Q1; for the turret (milling head, but for simplicity I'll call it the turret) to move into place, and the engagement pin to extend from the tailstock body, and the body will unclamp. When I do this, the turret moves, but overshoots right past the tailstock, and actually over travels before it stops. With this said, I am of the assumption that the tailstock engagement position needs updated. Following the instructions in the manual I can get to step 8 where it instructs me to change PC parameter as "D144.2=1". For the life of me, I can not find this parameter. I looked through as many pages as I can find, and I did find some "D" parameters, but there is no D144 anywhere. Anyone have any insight?
Forgot to mention, Fanuc based MSG-501 control.
