Mori Seiki CL-200 MSC-803 Reinitialize control/dead battery
Likes Likes:  0
Results 1 to 2 of 2
    Jun 2020
    Florida
    Default Mori Seiki CL-200 MSC-803 Reinitialize control/dead battery
    Good afternoon, I'm having troubles with reloading parameters back in after battery loss. The problem is that I didn't have reliable copies of my all1 all2 and all3 backup files. I've got original factory parameters from Mori, however once I load them and set x and z zero points I can move the axis, and index the turret, clamp and unclamp the Chuck but I cannot make any MDI commands, it won't insert them, and it shows I have no available space for programs. I'm not really familiar with the control, but I've learned a lot over this ordeal. Any help in the right direction would be much appreciated.
    Sep 2010
    Winder, GA
    5
    Quote Originally Posted by plowking View Post
    What do you mean by "reliable copies"? If you have anything at all, it might be helpful. A lot of those older machines actually came with a hard copy of the parameter list that had the original parameters from the factory. Did you lose that and that's why you had to get them from Mori?
