jack123529
- Jan 9, 2014
- Mexico, Rio Bravo, Tamaulipas
Hello eveyone.
I was hoping i could get some help on an issue on a mori seiki sl3 with a problem on x axis, when i move it on rapids 25%, 50% or 100% it shudders on moving, like when you try moving an axis with no oil or has something stuck, its oiled up well and it just started doing it in the middle of a part off cut. I moved it manually and i get the problem, i have no idea on what to check first so i figured i asked here if anyone had a similar problem before.
I get no alarms on screen. My guess is a bad encoder, thrust bearing or ballscrew, maybe a stuck gibb?other than that i have no idea.
Any help is apretiated, thanks in advance.
