Mori Seiki sl15 mc cuts horrible far from Chuck 8 inch to 4 inch from chuck
Results 1 to 6 of 6
    Jun 2018
    Default Mori Seiki sl15 mc cuts horrible far from Chuck 8 inch to 4 inch from chuck
    I'm newbie to all this Got two sl15 recently first machine cuts like butter second one I crashed into work piece when changing tool before cutting anything put program in cuts horrible our work piece sticks out 8 inches chatters and can't find sweet spot like other machine looks horrible noticed turret was moving by hand if pushed on it so tore turret off was looking for pins must of took out from previous owner couldn't find any put back together is a lot tighter no movement think nut came loose when crashed faced part left small nipple disnt do this before cut outside diameter looks little better then before but still not as smooth as other machine question is if i adjust again to where there is no nipple which is like 1/16 or less think that little bit would make it cut rough or do i need to realign spindle or turret slide and how much to have someone else do all this thanks for any help.
    Jun 2018
    More info we are cutting 303 stainless have order for 1000 parts really need second machine running this site has been tremendous help knew nothing in beginning programming was a pain but with manuals and your help learned in couple days running out of time would be great if someone would volunteer and send me email or number to speed things up thanks again for any help
    Aug 2010
    Connecticut
    2,225
    1405
    1837
    Look in the manual. I believe in section 8.1 Mori has a couple pages on punctuation. Should help with your problem.
  4. Likes yardbird liked this post
    Dec 2014
    New York
    702
    224
    173
    Make sure your cutting edge is on center and turret locked in! Otherwise you got what you got.
    Time to call a service guy...sounds mechanical to me.
    Jun 2018
    Quote Originally Posted by Kaszub View Post
    We ordered new tapered pins hoping this fixes it we got it so when we face it there's no nipple but cutting outside diameter still get swirl marks from chattering no matter what speeds and feeds we use . measured diameter and it's right on besides the horrible looking swirl marks. Checked spindle that runs true if tappered pins don't help checking slide I guess that's got pins in it too
    Dec 2014
    New York
    702
    224
    173
    Could be your spindle bearings too.
