Mori Seiki TV30 tool change procedure help
Likes Likes:  0
Results 1 to 2 of 2
    Feb 2019
    FINLAND
    5
    Default Mori Seiki TV30 tool change procedure help
    Hi
    I have some issue to figure out how Mori Seiki TV30 tool change procedure works. I got machine that has broken controller and it was changed to linuxcnc, and servos work great etc... but the issue is that I don't know how the tool change procedure originally worked? how the spindle claw will release? should it just work when spindle is oriented right way and you drive the spindle up?
    There is very little information anywhere about this or even videos showing clearly what happens so I just have to somehow figure this out.
    Feb 2019
    FINLAND
    5
    Ok Harri helped me with this, so it actually just opens claws when it moves up and closes claws when it goes down past certain point (lever).
