WaterVsAnchor
- Aug 9, 2018
Not a machinist, but thought maybe someone on here could help steer me in the right direction. Manufacturer with multiple DMG Mori machines, using Mori-Server for communication. Without administrative rights, Mori-Server launches but throws up a communication error when trying to talk to machines. This error appears to be identical to the one you'd get if the machine itself was turned off. If you run the software as an administrator, communication works just fine.
Has anyone else had this experience? Software has been run throughout the years on XP, Vista, Windows 7, Windows 10.. all with the same issue. We've put a bandaid on it in the past by allowing machinists local administrative rights on their machines but we are no longer able to do this and have to find a solution.
If there isn't one, is there a comparable or BETTER piece of software we can use for this functionality?
