Hi everyone, my first post, but I've spent hours and hours reading these forums, fixing my machines using the info I obtain for free. Thanks to all who work together here to merge knowledge bases, and past experiences into usable data for all of us.
This post is in regard to Mori seiki SL-1 No.499
Yasnac 2000b(single line) control
yaskawa drives
The issue I'm having goes something like this:
Power machine up
Power control up
power servos up
Machine is in ready state.
Wait.
Wait s'more
Wait s'more
(About 2-10 minutes)
Spindle system begins to buzz on and off(just a little juice actually flowing to the motor)
This symptom begins to get worse the more time elapse
The buzz and movement of the spindle becomes longer in duration(instead of a dot it becomes a dash)
Eventually the spindle begins continous rpm and gradually rises to approx 1100rpm.
At this point the spindle may continue to run at 1100rpmfor an hr or sometimes just a few seconds
The spindle will then slow to 0rpm briefly and then back up to 1100rpm
Sorry for the poor use of space there, I wanted the symptoms to read, just like they happen in hopes somebody familiar with this drive or someone who experienced this same problem in the past could shed some light on my demon drive.
Voltages all check out in terms of power into the drive and exciter.
Tach gen functions properly.
All relays seem to function correctly.
N.C. signal is always 0v during these outbursts.
If I immediatly fire up the spindle with the jog dial when I power the machine up the spindle works perfectly. No funny noises, no erratic rpm. It's rock solid......for about the same 2-10min before it becomes uncontrollable and acts exactly the same as previously described.
So please explain to me how a drive that is seeing no signal to the drive, drives anyways? Leaky scr's?
yaskawa drives
Power machine up
Power control up
power servos up
Wait.
Wait s'more
Wait s'more
