chad883
Cast Iron
- Jan 12, 2012
- indiana, usa
I have a Mori SL 25Y, while drilling a cross hole with a live tool the coolant ran dry. This stopped the drill and alarmed the machine. I got everything reset and homed out. The problem is that the live tool drive spindle is not oriented correctly. The slot in the drive that is supposed to be lined up with the slot that holds the live tool tang oriented when they are not in cutting postion. The drive slot is at about 2 o'clock instead of 12 o'clock. Not sure if I need to look for a parameter, or if it will be a mechanical alignment. Any pointers on how to fix would be appreciated.
