Hello,
I have a new-to-me Mori Seiki TV-30 tap/drill center.
I have gotten it mostly resurrected, by pouring through posts on this and other forums, and from generous help from members.
At this point, I'm a little stuck.
Control: Mitsubishi/Mori MSC-802M (basically an M50 with a Mori GOP (graphic operator panel) front end)
The control will freeze up if you press the "program" soft button. Then you have to power cycle. I am also missing the "caps-m" soft button.
The battery for the GOP had failed, and after replacing that and doing all the memory resets and procedures that I could find, I have come to the conclusion that I need to re-upload the GOP firmware. I know that it can be done from a PCMCIA memory card, but may be possible to do it through a dedicated GOP serial port as well. There is a Mori technical manual, might be called "Z2: GOP" that would be very helpful if anyone has it.
Has anyone been successful in working with the GOP?
Thank you
CArl C
Thank you
CArl C
