pri0ritize
- Mar 3, 2014
- Poulsbo, WA
So, I've been posting a lot recently asking questions about getting my new (to me) MV-35 up and running and I've run into some issues I was hoping someone might be able to help me with. Currently I've got the X and Y axis able to move when in the emergency release mode but not the Z. In the back cabinet the NF6 breaker pops on power up, I assumed that it was possible that I had the phases backwards and it was the hydraulic pump popping that breaker but I swapped phases and had no luck. From what I understand of the machine hydraulics should come on when I turn the control on, and that is not happening, currently sitting at zero PSI and there is also no power to the lube pump (or all the lights are burnt out). Anyone have an idea of why that breaker may be popping? I get a 49 Error - Machine Op Not Ready on control startup which flashes and kicks me to the tool input screen. Not sure why that is. The description of the alarm in the manual is De-energized magnet switch MS2 and MS6 in the electric control board.
