HI,
I have a problem on my DMU 60P Deckel Maho mill, I have install a new X Axis motor and X Axis linear measuring scale.
But my X measuring system in the MillPlus is now off by 0,2 mm fram the machine cordinal.
I have been told that I can adjust the machine parameter 3125 "zero point setting"
but if I change the value in this paremeter that makes no difference.
To check I use a dial indicator in the center off the round table, and then du G53 and turn the round table 180 dec.
I measure the new value on the dial indicator and is off 0,2 mm
Can someone help me ?
\CNC45
\CNC45
