Hello everybody I am needing some help, I've been struggling a bit with this machine I thought I had it straightened out but more issues have come up. I have dual ball screws on my X which are not quite in alignment with each other. When a zero return is performed I got a soft thermal alarm on V (the X slave). I have a procedure for "Adjustment of twin drive motor load X axis, however the problem is the procedure is for a newer machine and for the most part the menus are not even close to the same. I have been trying to struggle my way through this for the last day and a half with basically no results. My hope is somebody here has the procedure, I understand the process that needs to take place as far as aligning the ball screws go I am just not familiar enough with the menu system to get the adjustment done. I would greatly appreciate if anybody could help me out here. The machine was manufactured in October of 2004.
