Reference Piont Setup /Gildmeister GAC65
Likes Likes:  0
Results 1 to 1 of 1
    Nov 2018
    Alaska
    Default Reference Piont Setup /Gildmeister GAC65
    Hi there
    I am working on an 8-Axis lathe, Gildemeister GAC65 Series(1995). I've been repaired Spindle & servo drives, Monitor, EMG-Cards then and reloaded the machine.
    the battery was health after 8years being off, but the memory was erased.
    now, I can jog the machines axis but when I want to go to the reference point, the machine doesn't react and keep moving until the Termall-trip microswitch action.
    it happens on my all axis, I also change the motor and drive but nothing happened.
    I find a piece of paper, which is about: "to avoid involves moving the encoder then the reference point will require resetting."
    unfortunately, documents are corrupted.
    Does anybody have the same experience or suggestion?
    All the Best
    R.Teimouri
