SH-63 with an EX0159 alarm
Likes Likes:  0
Results 1 to 1 of 1
    Apr 2020
    Oregon
    10
    Default SH-63 with an EX0159 alarm
    Hello everybody,
    I've got a SH-63 that isn't playing nice, it's a rather odd situation that is racking my brain. When a tool change is attempted the machine will throw an EX0159, or an EX0161 alarm, and at a random spot through the ATC travel it is not at all consistent. I have found a few burned up contactors that have been replaced I initially thought they would be the issue. I can manually perform a tool change typically without any issue using M6; however in the ATC menu there is a flashing M003 in the upper right corner which prevents me from doing anything unless I use the interlock release at which time I am able to perform all tasks in the menu without issue. When running through the tool change either way it lines up as it should, and changes tools without issue however when a tool change is called while running a program it just won't do it. I am not sure where to check from here any help would be greatly appreciated.
