I am just curious if anybody has pulled a turntable out of their Mori? We have an SH-630 that is draining the hydraulic tank in about 30 seconds into the coolant tank when we rotate the B axis. This strongly suggests we have a damaged seal somewhere in the turntable. I've not dove into this before but thus far it's not been overly complicated but I have only got the top cap off. Now I am met with a massive brass bushing and a steel plate slightly smaller than the ID of the brass ring and just below it. The plate has 20-30 bolts around a 6" shaft in the center. The shaft has several O-rings that seal in the center of the top plate I have off. I am assuming at this point those center bolts come out and I continue my adventure down deeper into the turntable until I have found the damaged seal. Anyway if you have had the experience any pointers would be great.
Thanks!!!
Thanks!!!
