isaac338
Cast Iron
- Sep 25, 2008
- Halifax, Canada
I've got an issue with my Mori Seiki SL-3H; if you turn rapids to 100% and rapid the X-axis, it alarms out with an SV009 excessive following error.
Turning the gain up on the amp doesn't fix the issue, nor does adjusting the gain parameter for that axis. The 18xx parameters for following error are correct per the Mori manual.
This machine was bought with a bent X-screw which has been replaced, but that doesn't rule out some other mechanical issue.
I haven't tried loosening up the gibs - what's the correct procedure for setting the gibs on this machine? Is there a servo load readout somewhere that can be used?
Thanks for any advice.
