Tool changer magazine sloppy on Deckel 103V machining center
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2005
    48
    57
    Default Tool changer magazine sloppy on Deckel 103V machining center
    Hello,
    The tool magazine wheel will rotate back and forth if I grab hold of it and rotate it back and forth, maybe 5 or 10 degrees. My tool changes don't match with the spindle well due to this and it hits hard at times when changing.
    It is time for us to pull the unit apart and fix it.
    Anyone with experience and can pass along their wisdom would be greatly appriciated.
    Here is a video of the problem: http://www.sunspotedm.com/toolchanger.html
    The machine is a 1999 Deckel Maho machining center (DMG).
    Thanks, Chuck
    Last edited by Owl Engineering; 10-12-2009 at 11:54 AM. Reason: added the video link
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,375
    2861
    5648
    For my curiosity, what the heck is a 103V ? Is it Deckel or DMG ? What year is it ?
    Nov 2005
    48
    57
    Quote Originally Posted by Milacron View Post
    The machine is a 1999 Deckel Maho 103V machining center (DMG)
    Here is the video of the problem: http://www.sunspotedm.com/toolchanger.html
    Jan 2009
    Iceland
    44
    Default I think your in luck.
    At least the motor it self is not suppose to move, this is a problem with bolts that holds the motor unit / or you might have a broken plate somewere
    This is not going to be hard to fix.
    just go take a look under while someone moves the magazine.
    just be sure to have it in the right place when you fasten the bolts un less you know how to change the motor´s ref. point.
    I´m on maturnity leave right now but Ill go and have a look at my DMG 103V magazine and confirm the diagn.
    Good luck
    Nov 2005
    48
    57
    Default This issue fixed....BUT
    But, now I am locked in between a tool change. Please see 2 posts above.
    Thanks, Chuck
