Good morning forum -
I am cutting a 2" D2 and the cutting rate was less than 4thousands/min. using .01 brass. I changed the filters (because i didn't do it for several months) and now the wire keeps breaking. I don't know programming at all so i copied settings from someone that helped me years ago. Do these look correct for first cut? Anything else i should check?
voltage - 8
on time - 8
off time - 13
servo - 15
tension - 1500
wire feed - 8
flow - 9
resistivitiy - 2.5
flush rate - 06/06
override - 100
groove width - .01256
deflection = .00472
voltage - 8
on time - 8
off time - 13
servo - 15
tension - 1500
wire feed - 8
flow - 9
resistivitiy - 2.5
flush rate - 06/06
override - 100
deflection = .00472
