I am trying to get a 1998 FX-10 that has been in storage for 1.5 years running.
I have changed out the battery and loaded the exec.
I have not loaded the pitch error diskette.
I am getting the following errors when I turn on the control:
S03 Servo Alarm: NR 0046 X
Load Pitch error
M06 H/W Stroke End
I have done the following:
1) reloaded the exec
2) turned the control off for 10 to 20 sec and then turned it back on.
3) made sure the breakers were not tripped.
I do not know how to load the pitch error although I do have the diskette.
Is the fact that I have not loaded the pitch error diskette causing the S03 alarm?
I believe I wired the servos correctly. Are they located on the lower right side of the control?
Any help would be appreciated. I don't know were to go from here.
Thank you
Mark
Load Pitch error
M06 H/W Stroke End
Thank you
Mark
