Which bit is moving?
Marcus,
Good observations on your part. You made me dust off my memory banks and try to remember more clearly and rethink this application.
Initially, the plan was to use the X & Y movements of the U/V box but this was passed over due to its limited travels and questionable servo response due to the higher torque that would be required to move the entire mechanism. Power and flushing were taken from the lower arm and if I remember correctly, the arm extention
was affixed to the table to better support the weight of the long extention and use the travels and sensitivity of the X & Y axes.
I can't answer your question about the door. It either had no saftey interlocks requiring it to be closed or this had been removed by Spectrum. This machine was already highly modified as were several others Spectrum used for similar hairball applications.
Generator settings were totally made-up and were absolutely a cut-and-try event due to the now-unknown impedence from the much longer power cables and the large surface area of the tall cut. Initial cuts were made well inside the final width of the cut until successful settings were developed.
As one would expect, while dialing in the settings wire-breaks were numerous and rethreading was obviously manual and time-consuming, so once a steady cut was made, very soft servos were used to prevent crowding the gap, reducing wire breaks and aiding flushing. Speeds were very slow but speed wasn't at all important... just getting the thing to cut
at all was.
I've also realized that the slug shown in the third picture was
not from the bearing race, but a similar tall part Spectrum cut with a different machine modification. I'll leave it up with this disclaimer just so you can see how tall some parts have been cut. Sorry for this mix up, my face is red.
(Pssst... hey Bud, when you find yourself in a hole...
stop digging!)
This mix-up and my spotty memory has caused me to give Randy Bormann a call today as he worked for Bill and Spectrum and his memory must certainly be better than mine. You may also remember Randy as one of the best speakers on the EDM circuit in the late '80's and early '90's.
If I hear from him, I'll either have him chime in himself or I'll post what he knows.
Also, if the moderator would turn on the "edit" button for me, I'll get rid of the non-pictures that are taking up so much space in my initial post and move the thumbnails into it.
Now I'm gonna go watch the Super Bowl!
Bud
