4 axis cut
Likes Likes:  0
Results 1 to 3 of 3
Thread: 4 axis cut
    Oct 2018
    GERMANY
    19
    Default 4 axis cut
    Hi
    I run a Cut E-350 , i am programming with Visi
    Made a 4 axis program and i couldn't run it on the machine
    I started the machine and i had 2 error codes - CNB 50120 and EXM 0108 and 1 warning CNB 50121 (while working)
    Problem is that i don't have any troubleshooting or any hint for these codes about what could be wrong ,
    machine doesn't have all errors explained and debugged (anyone has a complete list with errors explained?)
    Any help would be appreciated
    Jan 2013
    Plainfield, Indiana, USA
    1,682
    1266
    905
    Contact APPLICATIONS department; they can explain error codes and should be able to send documentation for your machine.
    Oct 2018
    GERMANY
    19
    I am waiting for a reply from them
    Error is "Axis acceleration exceeds maximum limit"
    It stops while working , no error when i load the program
    The part i work on is 15 x 5 x 40 mm , one side has 3° , machine stops when starts the radius to inclined side
