Aftermarket Filterfilter units
Results 1 to 5 of 5
    May 2005
    Republic of Arizonia
    1,619
    478
    Default Aftermarket Filterfilter units
    Currently on a 25 - 26 day nonstop run of carbide parts. I'm gonna have a hell of a time getting it cleaned afterwards....
    I was wondering if anyone had tried separate self contained filter units for their wire EDM?
    If so,
    Was the unit worth the investment?
    I was thinking of the pricing Ebbco units to clean the work tank as the machine was cutting.
    Has anyone here used this manufacture?
    Aug 2010
    New England
    286
    34
    i have used Ebco filters many times. I prefer the one big filter over the many small ones. The filters can be dried out, dust knocked off and reused. you can add a pump and draw water from the worktank, filter it, then return it to the worktank. I have done that but mostly with AL parts. I have used diatomaceous earth filters as well from swimming pools. Hayward makes diatomaceous earth and paper filter vessels. The tanks are plastic not metal and as they are made for pools so they don't suffer the EDM mark up you see on EDM stuff. The earth filters are labor intensive but filter very well. Hope this helps. Don't forget to price the replacement filter media before making a decision.
  3. Likes roysol liked this post
    Dec 2007
    St. Louis, Mo.
    219
    59
    63
    We use a Transor filtration system at or shop. Our shop is set up for grinding both HSS and Carbide. Transor filtration systems are also used with EDM machines.
    Transor Filter | Oil Filter Systems | One Micron Filtration
    Bill
    May 2005
    1,619
    478
    Thank you for your replies.
    Sep 2017
    22
    I have used stand alone Ebbco units with my wire edm machines for many years.
    But we now are so space limited the Ebbco unit have been put in storage off suit.
    I would recommend the 10 micron filters. After a little use they filter the finer stuff just fine.
    Pun intend.
    Regards,
    John
