M. Roberts
Cast Iron
- May 11, 2021
Guys,
Take a look at the attached picture of my Di water set up on my wire EDM machine. To summarize;
-the city water enters the system via the copper pipe on the right
-there is a filter to catch any sediment that may be present, there is a pressure gauge prior to the sediment filter
-after it exits the sediment filter, the water flows into the first tank via Tygon hose which is equipped with a sight gauge/strainer.
-exits the second tank, and continues to the machine.
The issue being, that when the machine is in need of water, I like to fill it thru the Di tanks, but they seem to not have adequate flow thru them...as if they are clogged. So I get impatient, and fill the machine; that sends the resistivity crashing, thus the machine acts goofy until it reaches its happy place.
Would I be better off running the tanks in parallel versus in a series as such as the current set up (I just thought of this as I was typing)? Does anyone else have these issues?
Thanks for the input,
Mark
Mark
