Agie 100 error message
Results 1 to 8 of 8
    Mar 2019
    HUNGARY
    Default Agie 100 error message
    Hi all!
    We have an old Agie 100 wire edm machine.(1987). We have an error message 321.
    We have a step by step guide to reveal the problem but no result.
    Could someone help me?
    Sep 2005
    Batavia, Il
    99
    Default 321
    Did you check the LEDs status on the lower left 2 boards in the control cabinet?
    Which are out?
    If none pull the SUS-02 and look for damage
    Quote Originally Posted by B.G. View Post
    Hi all!
    Mar 2019
    HUNGARY
    Quote Originally Posted by EDM Support - Larry View Post
    Which are out?
    Hi.
    All LEDs are ok. SUS 02 board seems ok as well. Now we have other error message (173). The Z axis doesn't move down. I can move it only up.
    Sep 2005
    Batavia, Il
    99
    Default 321??
    Press reset
    What is the error message shown at top of list? The top message is the primary and the others are sometimes a result of it.
    Hi.
    Mar 2019
    HUNGARY
    Press reset
    Ther first message is 420 but this ok because the wire is not in the lower nozzle. 10-15 minutes after turning on the machine appears the error message 321.
    Aug 2010
    New England
    244
    30
    FYI 321 is 44 Volts missing check on back board bottom right corner you will find test point for 44VDC use ground bar on right for 0 reference.
    173 is Reference the Z axis. this is why it only moves up. up is towards the home position. depending on FW level it may make you home the U-V axis before allowing you to move z down again. keep that in mind
  7. Likes B.G. liked this post
    Aug 2010
    New England
    244
    30
    321 44v not ok. check 44VDC on back side of back board lower right corner use machine ground for reference
    173 is z not reference. home the z axis which is up position. this is why u can go up not down. You MAY have to home U_V after z depending on version of Firmware
  9. Likes B.G. liked this post
  10. #8
    Mar 2019
    HUNGARY
    Quote Originally Posted by agieman View Post
    Hi.
    44VDC checked. It's ok. I measured 52.7V. Message 321 still appears.
    Error message 173 solved.
