1. If you loose air pressure or the water tank level gets too low for example...once these situations are corrected, any way to clear the error on the control and get back to business ? All I can figure so far is to shut the entire system down and start over...a PITA...
2. Any way to do a "dry run" to check the table movements via the plotter pen on the back side without the darn thing wanting to go thru the wire cut sequence first ?
3. How to reset when you load a new job, hit "start job" and get a "(previous) job not finished" message ?
