Agie Charmille Cut200/300
Results 1 to 5 of 5
    Feb 2012
    England
    83
    Default Agie Charmille Cut200/300
    anyone with experience running any of these agie machines give me some info because what im being taught by someone, doesn't make any sense to me.
    when edge finding I noticed the lad teaching me has a added value of 0.5 in the measure cycle.
    after edge finding is done he enters 0.5 mm in the opposite direction + half of the wire thickness.
    sax,p,x-0.625. (measuring something on the right hand side of the table --> [ )
    surely you would just need to edge find with no added value in the measuring cycle and the machine should work out the centre according to whatever wire thickness. ive used an AC classic and thats how it works on there.
    Cheers
  2. Likes Mike1974 liked this post
  3. #2
    Nov 2014
    Florida
    4,131
    1620
    1941
    Is he comping for something else and just trying to do it one cycle? IIRC on a 290/310 wire edm, the command was -
    edg,x, x-.0052 (.010" wire, touching to the right) or something...
    Not sure why the additional value he is putting in.
    Feb 2012
    England
    83
    not sure what he is doing to be honest, I don't think he knows himself. I can understand adding 0.125 because maybe the wire edm doesn't work out the centre of the wire with one simple edge find but adding 0.5 then going back 0.625 is just plain stupid. after he enters sax,p,-0.625 he does home the machine [Home P}
    on the AC classic i normally just do the measure find and it automatically enters the value's in the relevant field. i'd just run the job, I wouldn't need to dick around with anything else apart from z height
    Mar 2016
    South Carolina
    75
    13
    Should have 0.00 in the measuring cycle unless he is compensating for material to be removed or his origin is in a different location than being picked up on. Sounds as though he is doing a full circle......edge find and move to zero if you have 0 inside measuring cycle.
    Aug 2010
    New England
    286
    34
    he is duplicating the function. does he have the X value to be entered at 0.0000. if so, then the center of the wire will be zeroed on the edge of the part and it will automatically comp for the wire, if the correct wire is active in the wire table.
