GABE SCHNEIDER
- Mar 11, 2020
After having this machine for 5 years and only 5,000 hours, it appears that we have a lead screw & bearing problem where they need to be replaced. After talking to charmille they said it could be due to lack of greasing or not doing so upon the grease cycle request. I can understand that but it is hard to beleive because the machine is so new with such low hours. I have always greased the machine when needed and have 4 other machines that I do the same maintenance on and have never had that problem before. Those machines have between 20,000-50,000 hours on them.
I am getting a (collision y- error) it does ok on straight cuts sometimes but it appears mostly when it gets into having to do a radius cut. Any help or advice from anyone else that may have or has encountered this issue would be appreciated
possible that the new brushless motor or bad parts out of the box on there end could be the result?
Side note the first year we recieved this machine we had the boards burn up and charmilles had to replace them at there expense under warrantry ( $25,000 )
