Agie Charmilles P350 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Oct 2018
    GERMANY
    6
    Hi , i am new in this field . i work on a wire and on a sink machine and i will start to use a fast punch hole machine also
    the wire machine is an AgieCharmilles CUT E350 , i work with the machine for about three months , so if i would have to make a list with the problems i had/have i wouldn't know where to start
    i work with visi peps , i had to make a program for a 165 mm height but i couldn't use the wire i have for that so i had to set 100 instead
    problem is that i have to "postprocess" that difference , what i did isn't showing an improvement so far
    material Steel 165 mm
    wire AC CUT VS 900 0,25 ( this supposed to be an alternative for big height but on postprocessor is maximum 100 mm )
    AC Brass 900 0,25 i normaly use
    any help would do
    thanks
  2. #22
    Mar 2016
    South Carolina
    57
    Cut P350 Update: let me first say this is a relatively new machine. So with that being said you still have the usual computer glitches, which agie routinely updates and fixes. Nothing major though, lol. I would still recommend the VP2 over the P350 because its way more user friendly and the vision control is in a class above the rest. BUT we do like the P350 its familiar and the annealed wire threads up flawlessly. We use Esprit to do most of our programming. Routine maintenance is a must with these machines. A lot of the "problems" we are faced with is just we arent familiar with the errors or alarms. As for radius compensation in the programming, you may be at a lost also. These machines are very picky when it comes to internal corners with radii are very close to yhe offsets. Especially when cutting tapers. Recently we had to redraw the geometry and write a 4 axis program on esprit before it would run the program.
  3. #23
    Oct 2018
    GERMANY
    6
    Quote Originally Posted by Girl23 View Post
    i have only changed the big filters , upper level sensor in clean water tank , and besides that i have only cleaned the dirty water tank and the working area . i haven't opened anything else .
    do you have any recommendation for a routine maintenance ?
    thanks
