Agie Mondo Star 50 Machine Setup
MikeTT
Apr 12, 2019
Anybody out there have a Star 50 machine & willing to share machine setup parameters as we lost ours when HDD failed? We have OPT 60A, EU, HIPOl (although this is not used). In particular we need to know what to set Capacitance, Poi-14, Peak Amps, Average Amps & ACO Bitmask. Machine is currently 'working' but doesn't seem to be outputting enough power. Thanks in advance!
Do you have the techno book usually edms always have a book
Sent from my LM-X410PM using Tapatalk
It sounds as though you know where to set these options, but
I will assume that you don't. When the machine is booting and
is on the windows start page you must drag the cursor off the
bottom of the page. After the mondo software is up you will
go to the "Configuration" page. You sould find the tab
"Machine Setup".
If you have optional amps and have two GPM-50 boards (power
boards) your peak amps should be 128.
Your average amps should be 100 Amps
If your machine has a small box on the right side of the
Z axis it has a POI-14 board.
If your machine has HIPOL then it has capacitance
ACO bitmask depends on what DRT board you have
This board is the board on the lower rack farthest
to the right
"Machine Setup".
to the right
Thanks for the response. We have DTR-50 on the far right. 2nd GPM-50 is not used & unplugged from the rack.
Apologies for any confusion - we only have ONE GPM-50. (The unused board is GHP-05). What should the current settings be in this case?
