Agie Mondo Star 50 Machine Setup
Results 1 to 6 of 6
    Apr 2019
    UNITED KINGDOM
    Default Agie Mondo Star 50 Machine Setup
    Anybody out there have a Star 50 machine & willing to share machine setup parameters as we lost ours when HDD failed? We have OPT 60A, EU, HIPOl (although this is not used). In particular we need to know what to set Capacitance, Poi-14, Peak Amps, Average Amps & ACO Bitmask. Machine is currently 'working' but doesn't seem to be outputting enough power. Thanks in advance!
    Mar 2019
    ALAND ISLANDS
    6
    Quote Originally Posted by MikeTT View Post
    Do you have the techno book usually edms always have a book
    Sent from my LM-X410PM using Tapatalk
    Aug 2008
    westfield,ma
    34
    It sounds as though you know where to set these options, but
    I will assume that you don't. When the machine is booting and
    is on the windows start page you must drag the cursor off the
    bottom of the page. After the mondo software is up you will
    go to the "Configuration" page. You sould find the tab
    "Machine Setup".
    If you have optional amps and have two GPM-50 boards (power
    boards) your peak amps should be 128.
    Your average amps should be 100 Amps
    If your machine has a small box on the right side of the
    Z axis it has a POI-14 board.
    If your machine has HIPOL then it has capacitance
    ACO bitmask depends on what DRT board you have
    This board is the board on the lower rack farthest
    to the right
    Apr 2019
    UNITED KINGDOM
    Quote Originally Posted by jdd View Post
    "Machine Setup".
    to the right
    Thanks for the response. We have DTR-50 on the far right. 2nd GPM-50 is not used & unplugged from the rack.
    Apr 2019
    UNITED KINGDOM
    Apologies for any confusion - we only have ONE GPM-50. (The unused board is GHP-05). What should the current settings be in this case?
    Aug 2008
    westfield,ma
    34
    peak current should be 64 average amps 50 or 60
    aco bitmask 63
  7. Likes MikeTT liked this post
