Agie Progress VP2 Alarm
Girl23
Mar 8, 2016
Our VP2 has started giving an alarm dielectric temperature out of tolerance.......the chiller temp is reading 54 degrees. When it alarms out, it drops the water level and turns the DA off. Anyone else had this to happen? Finally had to go into parameters and adjust the maximum temp.
Just to clarify, is that 54F or 54C?
Because 54F is a bit too cold, and 54C is much too hot - sounds like it's time to service the chiller.
Dan
54F is not to cold! these machines use a closed loop system and a heat exchanger. you need chilled water to be at least 10F colder than what you want on machine side for exchanger to work effectively. 54C is definitely to hot! lol
check the valve controlling flow of chilled water to heat exchanger YV31 may be stuck open or closed. check amount of water in chiller. when this just comes on out of nowhere chiller reservoir is usually low
