Agie Progress VP2 Lines in Punches
Likes Likes:  0
Results 1 to 4 of 4
    Mar 2016
    South Carolina
    75
    13
    Default Agie Progress VP2 Lines in Punches
    My Agie VP2 is leaving a bad finish and lines in our punches. Initially we thought bad steel, but its consistently leaving lines on carbide too. Its on the same spot, on the same side of every punch cut. We tried bigger tabs, more material left between each punch.
    How do you attach pictures?
    Aug 2010
    New England
    311
    38
    hi, send me your pics or call me
    Apr 2010
    uk
    111
    What wire are you using? are you also using correct technology? parallel or taper? what's the cutting and flushing conditions like?
    Jan 2020
    Illinois
    6
    Check the condition of the safety filter. The filter should be cleaned often depending on the amount of muck in the clean tank.
