AgieCharmilles CUT 20 P Breaking Wire
Results 1 to 8 of 8
    Sep 2003
    Alabama
    19
    Default AgieCharmilles CUT 20 P Breaking Wire
    As stated this machine suddenly started breaking the wire. It may break as soon as contact is made with the material or it may cut for a couple minutes before breaking. I haven't run this machine much and need some guidance on what to look for.
    Dec 2015
    Ohio
    44
    13
    14
    I don't run a cut 20 but it sounds like one or more of the following. Wrong power setting, poor flushing,worn contacts, worn power feed cables, or maybe breakage strategies turned off.
    Aug 2010
    New England
    230
    27
    what material? How thick? check contacts, change wire, flush working? how close are nozzles? they should be .002-.004 away. why not call GFMS?
    Sep 2017
    10
    The tricky one is a worn lower contact. The controller "checks for spark quality feedback" there.
    Feb 2007
    Angleton, Texas
    1,768
    938
    528
    Had a CUT-400 do that for no apparent reason.
    Turned out to be bad caps in the cutting power supply.
    Aug 2010
    New England
    230
    27
    cut 400 cut 20 not the same generator
    Oct 2017
    ROMANIA
    13
    try to increase SSol parameter (60-70) and decrease P parameter (15-30), also decrease by 1-2N wire tension - all of this from the tec. optimization
    Aug 2010
    New England
    230
    27
    check lower contact wetting. procedure is described in chapter 8 Maintenance section 3.10 also check upper contact wetting section 3.9
