Hi all
I am quite new to wire EDM, I got an Agiecut 250 FS HSS. I am currently working on some tall parts (160mm high and the cut I need to make is only 0.3mm wide). I am working on this since a couple days, so far it worked well, but today I got some issues and I wonder what could be the reason for that.
First of all, I have problems that my wire is often ripped off in the centre of the cut. I believe this is because the cut is so narrow and my part is so tall, that the flushing is not very good. How can I improve the reliability?
Second, and more specific to this machine, I have following two problems: sometimes, when the wire breaks and needs to be threaded after it has been ripped, the water jet is a bit too weak and has bubbles in it. Then the wire isn't properly guided and the automatic threading fails. This is especially annoying when I let the machine run over night. However I replaced the water filters, and I do have enough water in the tank. Is this a common problem with this machine, does anyone know whethere there are any "notorious" parts causing that? would it be a smart idea to change all the installed hoses?
Further, since this morning, I have a new problem: the wire gets properly threaded and everything works nicely, but after a couple seconds, I get the error message that the wire is ripped off or not properly threaded. According to the manual, I found out that this problem could be due to the "wire detector". So I pulled that out according to the manual, and cleaned it (was not really dirty, but anyway) and reinstalled it. Still no success. The manual says that the wire detector shall have a distance of 2.6mm to the wire; how critical is that? any experience with those detectors? the manual also says that if the error persists, the wire detector is faulty and needs to be replaced. However, the wire detector has only one single electrical wire attached to it, so I wonder how it works and how it can get damaged. And of course, as an electronics engineer, I wonder whether it is possible to fix that problem. Any experience with that? However I am not really sure whether the wire detector is the actual problem; I noticed that the little green wheel on the head does not rotate smoothly but sometimes runs a bit jerking, so perhaps the problem is more likely with the wire or the transport belts? I already did the demagnetizing procedure of this little wheel (also according to the manual), but it didn't help.
Unfortunately, I have never looked at this wheel so intensively, so I cannot tell whether it ran smoothly before or whether it was always a bit jerky.
Yesterday I had to replace the wire spool, and I did that step by step according to the manual, and afterwards the machine worked very well until this morning. So I wonder whether I possibly did something wrong when inserting the new wire into all those wheels and stuff. Is there any pitfalls or problematic things one should know about this and which are probably not mentioned in the manual?
I got the machine from a friend who used it in his own workshop, it seems like the machine worked reliably since 1996. The only reason why he gave it to me was that he needed a larger one, so I assume the machine itself should be actually OK but I guess the origin of most problems is the operator ;-) my friend gave me a short introductory course, but is in holidays now so I cannot ask.
