Agiecut Classic S. Water Pressure While Filling Tank.
Likes Likes:  0
Results 1 to 2 of 2
    Nov 2017
    Virginia
    6
    Default Agiecut Classic S. Water Pressure While Filling Tank.
    At the very beginning of a job when the machine is filling up the tank the bottom water nozzle begins to spray at high pressure (shooting over the door and onto the floor)Before the tank is full.
    Doesn’t matter what I have the pressure set to, as soon as the cut begins it goes to whatever pressure has been programed for the entry cut.
    I have tried lowering all the pressure settings, but they do not seem to apply to when the tank is filling.
    It doesn’t do this if I manually fill the tank to check the level.
    Thanks. David.
    Aug 2008
    westfield,ma
    15
    david,
    I believe the valve yv22 is staying open when it should
    be closed. the line marked 220a is flushing pressure going
    to the lower head that yv22 controls. the valve may need
    replacement.
    Jim
