Agiecut Wire EDM issues
Likes Likes:  0
Results 1 to 12 of 12
    Jan 2015
    New Jersey
    Default Agiecut Wire EDM issues
    Hello, I have a Agiecut Sprint Wire edm. I believe it is close to an Agiecut 100. I was hoping someone can help me. I am having a problem with short circuit. The machine cuts fine until it goes into a corner. Once in or close to a corner, it short circuits and stops. I tried a large radius, small radius and no radius. All with the same effect. Can anyone direct me on what to do or try?
    Thanks in advance
    Aug 2010
    New England
    295
    35
    try turning off corner strategy and see if it does the same thing
    Jan 2015
    New Jersey
    Thanks for the reply. I never had to change this. Can you tell me how to change the corner strategy?
    Thanks Again
    Aug 2010
    New England
    295
    35
    it is the str value or the erosion S page i believe. i am not sure this is the problem though because you state it will happen in a sharp corner. By sharp corner you mean no radius at all yes?
    Aug 2010
    New England
    295
    35
    sorry set to 0
    Jan 2015
    New Jersey
    Thanks, I will try this tomorrow morning. I will be sure to update my findings. I greatly appreciate your help.
    Jan 2015
    New Jersey
    Hello,
    I tried this and the only thing that changed was the machine didn't go into short circuit. It kept backing away from the corner and then moving toward the corner continuously. Never did it try to turn the corner. I hope that makes sense. Just trying to figure this out. I appreciate your time.
    I was trying this on 1.5 thick material, I tried the same cut on 1/2" thick material and it cut almost as it should with the original strategy setting.
    May 2011
    IL, USA
    13
    Default Support
    Quote Originally Posted by Nj machinist View Post
    Hello,
    Try calling GFMS (847) 955-7100 ask for either Marc Godin or Tony Zienner.
    Mar 2007
    Brentwood Bay, BC
    133
    What kind of material are you cutting? I had the same problem once, it turned out it was a dirty piece of 4140 with lots of impurities. Sometimes it would cut around the inclusions, and finally it was acting like your machine. I never completed the cut.
    Mar 2020
    Illinois
    Has anyone successfully accessed files from a Windows 10 machine with Agiecut Classic V.3? Wasn't sure where to ask this
  11. #11
    Aug 2010
    New England
    295
    35
    are you using the same tec file for the different thicknesses? are you sure its tec for 1.5 in thick material?
  12. #12
    Jun 2013
    Ohio
    29
    5
    5
    agieman: This post is two years old.
    rohodyer: You're better off to create a new post for your question with a subject line that restates your query. Tacking your question on to the end of an old, unrelated post just leads to a)confusion and b) your post not being seen by the right audience.
    Dan
