Carter1206
- Jan 28, 2022
Have a old school 1970s agie ag 33 stm sinker machine and out of nowhere it doesn’t turn on. Green light turns on with on power switch on but the red voltage button that actually gets the machine on and voltage reading on the meter is not doing anything. Tore it apart and cleaned most stuff with contact cleaner and die electric grease, contactors/relays look ok, all fuses are good, No burnt or loose wires or anything out of place either. Was using the machine an hour before it stopped. Didn’t even shut off when using it. Was when I went to turn it on to make a new cut that i found all this out. Any thoughts?
