Alarm Problems with Mitsubishi Wire EDM - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Jul 2020
    MALAYSIA
    Quote Originally Posted by jm0502 View Post
    Battery in the xy board was bad.
    Can any one shows me the location of the battery
  2. #22
    Oct 2015
    111
    148
    12
    Quote Originally Posted by tvalenzuela1432 View Post
    Do you know what a Y02 0002 2508 alarm is? I found it in book but no ref to what the 2508 code means.
    Tvalen1432
    Just FYI but found out this alarm happens when low volts are coming into the machine and therefor not a problem with the machine necessarily. Usually when machine is on and building looses power.
    Tvalen1432
  3. #23
    Sep 2017
    Ohio
    10
    6
    Quote Originally Posted by damian27 View Post
    You were right, after I replaced the battery and switched off all the power, all alarms has gone. Thanks for your help guys!
    I am having this same issue. Would you please instruct as to were I may find this battery?
  4. #24
    Sep 2016
    21
    What is alarm S03 servo alarm :NR 0057 X? On Mitsubishi Cx20 wire EDM ?
  5. #25
    Dec 2012
    UK
    76
    13
    We just saw this alarm on CX20 machine, had to replace 3 axis servo amplifier!
  6. #26
    Sep 2016
    21
    Was not enough to replace only the top board , the one with the display codes. ?
  7. #27
    Jul 2020
    SPAIN
    44
    8
    Hi Rocha,
    Unfortunately not, should be changed everything in order to clear the alarm for sure. Are you sure the problem is on the upper one? because usually the problem is on the middle one but could happen that is in both or in the entire amplifier, that's because must be changed the entire amplifier.
    Best Regards.
