jwatts
Hot Rolled
- Apr 19, 2006
- Missouri, USA
From my previous post I was pointed to where the fuse was located for the motor which drives the wire transfer belts. There turned out to be insulation rubbed of the wires causing a short in the motor that was blowing the fuse. After addressing that issue, the motor once again runs but only at full speed. Is the speed regulation for that motor accomplished on the same board where the fuse was located? Also, there appears to be a smaller motor piggybacked on the main motor, what is this motor for?
