Brother hs-300 resin bottle setup, missing from machine
Likes Likes:  0
Results 1 to 7 of 7
    Mar 2005
    Southwestern Ontario, Canada
    131
    9
    5
    Default Brother hs-300 resin bottle setup, missing from machine
    Hello, just checking to see if anyone has, or could take a couple of good pictures of the resin bottle setup. Also, if anyone knows how the system works? Is there a solenoid or something that opens and allows water to flow thru the setup when the system needs to bring the conductivity down. I need to figure out a replacement for it.
    Mar 2005
    131
    9
    5
    Anyone? I have a wire hanging out of the control box and capped off, would this go to the solenoid that I think should be there to allow water thru, or bypass the di bottle.
    Jan 2011
    South Florida
    664
    66
    126
    On mine the wiring is all in the bundle and no wire hanging out anywhere. I have a larger after-market tank, so not much help for you there. The hoses run to and from the tank on a secondary pump. Check that.
    The pump will only run when you have the water turned on and the tank is full enough to keep the condition sensor covered with water. I put the hose coming out of the pump into the main tank with the filter.
    Like I said, if that sensor is not covered and reading, the pump will not circulate the water through the resin tank. Best to have the water valve in the machining position and not the fill position as the flow is less and it is easier to keep the water level up.
    Sounds like, if your tank is actually missing, that you will have the hoses from the pump blacked off or hooked together.
    First pic is off the internet and the second is mine. It is crowded where mine is.
    Good luck---Mike
    Attached Thumbnails Attached Thumbnails dsc03032.jpg   20191023_092210_resized.jpg
    Jan 2011
    South Florida
    664
    66
    126
    deleted post
    Jan 2011
    South Florida
    664
    66
    126
    Don't you just love it when you put effort in helping someone and you never hear from them again?
    Mar 2005
    131
    9
    5
    Yes I love it too. Found a di filter and a solenoid on eBay. Easy setup. Thanks for the pics and description. Only just got it working, far too busy with paying work to be messing around with a machine instead.
    Jan 2011
    South Florida
    664
    66
    126
    Glad it's up and running!
