sfuller737
- Mar 30, 2020
Hi Brothers,
I have Brother HS70-A wire EDM machine that I am trying to get running. It boots up but it has a couple memory faults I'd like to clear up. 8351 Disk size error and 5108 memory not formatted. I also get an occasional fatal 8003 Ram error (Main/Wire) fault.
I can access programs but if I page down the list: 7998 **Kernel Error!
I can access the data bank but parameter greater than #500 are full of bad non-numeric values. I can access all the machine's operational parameters.
I cannot get to the format function on this machine. I just get a blank display.
I found both battery packs non-functional.
I suspect the compact flash card is corrupt and I have ordered blank replacement card 128Mb. I don't know if that will work or not.
Anyone have experience putting a new card in these things?
Can I/should I be able to read the card in a PC?
Is there more to the card than machine parameter and user programs?
I am hoping to stick the card in, format it, have the parameters re-entered (which I have recorded) and voila. I'm expecting to have to use a hammer somewhere along the line so as not to cause RAM error in my own brain.
