Brother HS70A EDM recovery disc Software
Steve Burrows
Jun 3, 2019
I am in need of a copy of the software disc to recover my Brother EDM that had a back up battery failure and lost its software. Brother EDM Manufactured 2007-07 Serial # 111550 HS 70A. Can anyone point me in the right direction? Thanks.
I, too am an un-supported brother owner. 2005 HS-70A
Right now I need a tensioner brake. I would also love to have the recovery disk if you found one
Steve
There is a PDF Brother maintenance manual for the HS70A-M.
Regards,
Brother John
Editing!!! I reread the PDF again. My hard copy says "reset" and the PDF says "clear all" and describe the same procedure.
My hard copy says "clear all" and the PDF says "clear ram" and describe the same procedure.
So to simplify the PDF that I attached for everyone to read/use the PDF "clear all" will reset the 11 system file on the CFC less the machine specific parameters.
I'm stay away from the PDF "clear ram" procedure.
