Charmiles robofill 440sl Over travel problem !!!
Likes Likes:  0
Results 1 to 6 of 6
    Jul 2017
    LITHUANIA
    7
    Default Charmiles robofill 440sl Over travel problem !!!
    Hello to everyone,
    we got a issue, when -Y axis moved to the table and we got y- overtravel error. We turned off the machine, and then the all axis went red to "Referece" mode. But we couldn't go to reference point becouse we cant move y+ on jog mode.
    We tried to power off the machine and than manualy move axis, but nothing changed. Any solution?
    We have the older robofil 330f machine, we hold down "Delete" button and then the parameter protection is off and we can move axis and then find the reference point. But we affraind to do this on a newer machine.
    Thanks for any help!/.
    Oct 2007
    PA
    12
    Try going to CNC Configuration. Hit the Initalize HER button. You might need to set the jog increments to the lowest increment to move the axis both ways, maybe hit the reset button.
    Sep 2017
    22
    Have had the same problem but in the +Y direction, when very close to the +y limit.
    A carful deep cleaning of the groves in the lower arm bellows helped.
    Regards,
    John
    Oct 2017
    INDIA
    Dear sir
    Machine completely on after press emergency and go to SDF page parameter page open and click (+) oprn next page select the pmc page next keep realy k1 0000000 in put the 1 in right side 6th one 0to 1 its automaticall zero machine off completely after on problem slove take reference
    Oct 2017
    INDIA
    If either same problem one time try to travel setup
    Oct 2017
    INDIA
    More help to contact
    [email protected]
    Supports
    agiecharmilles machines only
