Charmilles 440cc edge find
Likes Likes:  0
Results 1 to 11 of 11
    Oct 2015
    UNITED KINGDOM
    10
    Default Charmilles 440cc edge find
    Morning, having a problem with a charmilles 440cc when trying to do a edge find cycle against a ground job the wire appears to be snapping after having tried all the standard stuff changing contacts, electrical touch etc i have came to a dead end and was wondering if anyone had any ideas?
    there is voltage running through the wire and nothing tripped in the electrical side cabinet have also contacted charmilles and tried numerous suggestions from them.
    Thanks, Chris
    Nov 2014
    Florida
    4,048
    1611
    1880
    Have you tried any other cycles, hole, alignment, center? Tried edge find in different directions/axis? Just tossing some ideas out there, you said you tried all the obvious stuff like checking ground and such. Maybe just one direction, like X+ is screwy?
    Oct 2015
    UNITED KINGDOM
    10
    Yes tried all of the above just get same result with the wire snapping each time
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Have you verified the correct .WIR and .TEC files are activated?
    Verified that the upper contact wetting is adequate?
    Checked the upper contact and pinch rollers for grooving?
    In the absence of any problems in these areas:
    We had the same problem on our CUT-400 and it turned out to be bad capacitors in the power supply.
    Nov 2014
    Florida
    4,048
    1611
    1880
    I ran an older Charmilles 290 and 310 and sometimes they did some strange stuff. Have you tried re-initializing the machine? That was my last resort if nothing else worked. On the 290 sometimes I had to pull and re-seat boards and reload software. It was not well maintained I should say...
    Oct 2015
    UNITED KINGDOM
    10
    have checked all of above still having no luck, maybe capacitors as suggested?
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Quote Originally Posted by CMD1992 View Post
    If it's like ours, you'll know for sure in about a week when it stats popin' real loud and blowing sparks out the bottom of the cabinet ...
    Aug 2010
    New England
    281
    33
    quick question. is it breaking wire before contacting the piece or after?
    Apr 2013
    San Diego
    9
    16
    10
    Sorry to "Jump a thread" but I saw "Charmiles" and couldn't resist! I was hoping that you could help me locate information for a Charmilles EDM. If you could help me to locate an operating guide or a manual for a Charmilles Eleroda 110 EDM sinker machine I would appreciate it! Charmilles no longer supports this machine and I cann only find a manuel for $500!
    Thank you!
    Ian
    Oct 2003
    East Peoria, IL, USA
    5,407
    352
    807
    reinitialize, or even reload your software from disk. my console 2 robofil forgets stuff like this occasionally if it's turned off for to many days... sometimes it forgets how to switch pumps on, or how to edge detect...
    I'm living on borrowed time I know... but my borrowing rate is much cheaper than financing a new one so i will keep borrowing until then.
  11. #11
    Oct 2014
    29
    I have a 440 machine but its not a cc. I had problems with wire breaks and it ended up being my homemade carbide contacts. I put the
    charmilles carbide in and never had a problem with it after that. Different carbide has different electrical properties. I have several other
    Charmilles and no problem with my carbide contacts. You might try that.
