Pro-Tech Tool
- Oct 14, 2020
- Frankfort IN. USA
I have a Robofil 440CC that I am having wire feed issues with. It is not in the motor because when it does work it feeds fine. When I push the feed start button on the remote, the light just flashes but nothing happens. When I try to start a program, the light on the remote starts flashing when the wire should be feeding, the tank fills, the generator and fans kick on, sometimes the injection pump will come on, sometimes not. But the wire will not feed. when the generator kicks on, The program will keep going through the lines of code, and the head will move. As soon as the wire hits the part, (because the wire isn't feeding) it will break the wire. When this happens the machine will not give me any error codes, the head just keeps moving as if nothing happened. I don't understand what is going on. And why I'm not getting any error codes. Any help or suggestions are appreciated.
Thanks so much!
Thanks so much!
